Can we use File Upload Field in Form Component of Ignition 8.3?
@drey, not currently. We’re working on adding a new file upload widget to the Form Component for a future release.
okay! thanks for the reply @pamato .
just for planning purposes, do you have an estimated date or release window for when the file-upload field will be added to the Form component?
also will it be possible to suggest a workaround?
Development is ongoing but we’re currently targeting 8.3.3 for this feature. Depending on your workflow, you might be able to utilize our stand-alone Perspective Component pallet File Upload component.
I'm curious how this will work in offline mode (if at all).
Hi, with the upload file component in perspective: Is it possible to queue uploaded files when there is no connection to the gateway?
