I am trying to open a file using Ignition’s scripting
the format of the filepath is:
Code:
filepath = “\machine\c$\Logs\03_filename.log”
file = open(filepath)
but the console returns:
Quote:
No such file or directory: “\machine\c$\Logs\x03_filename.log”
The problem as you can see it is adding the character “x” before the filename prefix (day of month). If I rename the file as simply “filename” it opens the file ok. Day 31 returns “x19”
If I add a ’ it removes the x but also the backslash altogether;
Code:
filepath = “\machine\c$\Logs’03_filename.log”
Quote:
No such file or directory: “\machine\c$\Logs03_filename.log”
Tried to split and concatenate, with both single and double quotes, or a mix, some add a space into the result returned and some return the original result
