Filter Label columns in Alarm Status Table
Good morning,
I would like to insert in the alarm status table page a textbox where the operators could insert a name to search and filter it in the “Label column”; for example insert “Probe XXX” and filter the table based on the results.
I’ve seen that already exist other search option in the property of the Alarms Status Table, but I can’t look for the Label column.
Thanks a lot for the help
What do you mean ? The built-in search field does filter on the label column.
Actually I’m talking about the Vision Alarm Status Table, are a little bit different the filter option. As you can see in the picture there are 3 kind of filter but none is bind to the Label column… Maybe with a script or something else could be possible do it.
Make your textbox, and implement the filterAlarm extension function on the table, referencing the value in the textbox.
Thanks for the reply.
I solved it with this script in the filterAlarm Extension Function of the Alarm Status Table if can help.
	AlarmList = alarmEvent.get("Label").lower()
	ExFilter = self.Filter.lower()
	if ExFilter in AlarmList:
	    return True
	return False
