Filtering a table with Named Querie with 3 checkboxes in Ignition Perspective
Hello!
I would like to filter a table with 3 checkboxes, depending on wich checkbox I choose the content of the table is filtered.
Each checkbox corresponds to a possible value in one of the table's columns.
Is posible do this with bindings or is better with a script in Phyton.
Cheers
Do you know about the table's built-in column features?
columns.n.filter.enabled : true
There are other options in columns.n.filter as well.
Show your dataset and explain your checkboxes.
I didn´t know about the columns.n.filter.enabled : true
Now I changing it:
This is the part of the named query that show column ESTADO in my table
  (CASE
    WHEN WORKREQUESTSTATE='00' THEN 'Pendiente'
    WHEN WORKREQUESTSTATE IN ('10','20') THEN 'Generada OT'
    WHEN WORKREQUESTSTATE='30' THEN 'Rechazada'
    ELSE 'Estado Desconocido'
  END) AS ESTADO
This are the 3 checkboxes:
Checkboxes and table are in the same Column Container
So, you have a table of data where one column is ESTADO (status) and you want the checkboxes to enable display of one or more ESTADO conditions?
Checkbox Result
None Show only Estado Desconocido.
Pendiente : true Include Pendiente.
Generada OT : true Include Generada OT.
Rechazada : true Include Rechasada.
Is this correct?
None option should show all the rows
the rest is ok
Bad idea.
Ok, then the other way around would be fine, the way you tought
Checkbox Result
would need to have all checkboxes selected from begining
We will return all the records to a custom property. Then we will use a script to display only the records of interest. This means that we only query the database once.
  1. On the table, create a custom property, custom.data.
  2. Put your query binding on that.
  3. On the table data property configure like this:
The script transform.
	output = []
	for row in value['data']:
		if value['chkPend']:
			if row['ESTADO'] == 'Pendiente':
				output.append(row)
				continue
		if value['chkGene']:
			if row['ESTADO'] == 'Generada OT':
				output.append(row)
				continue
		if value['chkRech']:
			if row['ESTADO'] == 'Rechasada':
				output.append(row)
				continue
		if row['ESTADO'] == 'Estado Desconocido':
			output.append(row)
	return output
Following your instructions but seem something not working right:
Maybe is not clear where the error is, cheers.
Edit your Prueba-13 named query and remove the filter parameter. You want it to return all the records. The script will do the filtering.
Wait: is that a different radio group or the filter radio group?
In your screenshot you have cut off the preview. What is the result of the query?
Sorry, I forgot to tell you to set the query Return Format to JSON (which is what the script is expecting).
This part of the custom.data is working fine now
the part of the expression on the table.data seem to have an error
maybe this helps:
See post #12.
Wow, working great!, thanks Transistor.
Now I will try to start with all checkboxes selected and add the radio button filter we did yesterday.
Cheers.
Ok, just added the radio button filter as you teach me yesterday in the custom.data binding and both are working fine together.
Good work.
Suggestion: I think your full-cell color is too much and black on red is never good. Here's a trick:
Modify the style and set the left border to 20 px and add some color there instead. You get a nice indicator with an easy-to-read text beside it. There is no need to "scream" color! Be cool, man! Be cool!
Subtle color indicator
You need to do this for each different style that you use.
Thanks for the advice! just implemented it.
