I am trying to use the example in the manual for system.net.httpGet and I am unable to figure out the correct expression and match to pull the data values I need. I am able to reach the page and get the string of info back but I am to get the information I need out of it.
The data I need is coming back in this format Value
I think this topic may help you out.
Your post helped but I am still screwing up something somewheres.
A system.net.httpGet gives me <temp_f>51.0</temp_f>
<r_humid>99</r_humid>
My script is to extract the values from that is [code]response = system.net.httpGet(“http://191.192.168.50/index.xml”)
import Python’s regular expression library
import re
NOTE - if you’ve never seen regular expressions before, don’t worry, they look
confusing even to people who use them frequently.
pattern = re.compile(’.?<.?>(.?)</.?>’, re.DOTALL)
match = pattern.match(response)
if match:
subText = match.group(1)
temp_f = re.compile(’.?temp_f"(.?)"’).match(subText).group(1)
r_humid = re.compile(’.?r_humid"(.?)"’).match(subText).group(1)
print "Temperature: ", temp_f
print "Humidity: ", r_humid
else:
print ‘No Data’[/code]
Only part that’s working so far is the print 'No Data"
Could you post what gets returned from the httpGet? That might let me wrap my head around it a little better.
EDIT: Never mind. I need more coffee…
Let’s try simplifying a bit.
re.findall will return a list of values:
[code]response="""<temp_f>51.0</temp_f>
<r_humid>99</r_humid>"""
import re
match=re.findall(pattern, response)
print “temp_f:”, match[0]
print “r_humid:”, match[1]
[/code]
