Filtering Dataset using expression binding
Hello, there is function that I can use on EXPRESSION Binding
to get 2 first row of dataset ?
For exemple, I have :
What I want to show is:
Not directly. The Expression Language dataset operations are limited.
https://docs.inductiveautomation.com/display/DOC81/Expression+Language+and+Syntax#ExpressionLanguageandSyntax-DatasetAccess
You could script a transform on the data binding.
	pyDs = system.dataset.toPyDataSet(value)
	headers = system.dataset.getColumnHeaders(value)
	data = [pyDs[0], pyDs[1]]
	return system.dataset.toDataSet(headers, data)
If I don't mention it, Phil will be along to remind me that you should put the script in the Project Library and call it using the Expression Language runScript() function.
Thank you @Transistor I'am using VISION, I think I can't do transform script into vision :face_with_open_eyes_and_hand_over_mouth:
Yes, in my Integraton Toolkit module. The where() expression function, in particular.
If you just want specific row indices, like the first two rows, use idx() in the condition, like so:
where({path.to.source.dataset}, idx() < 2)
If you actually want to check the content, like matching the 3-letter prefix on ProductCode, you'd do something like this:
where({path.to.source.dataset}, left(it()['ProductCode'], 3) = 'BAN')
You need to add the Vision tag to your question.
That is mean if I want show 20 values of rows, I must repeat this line 20x ?
Also look at the transform() function. :laughing:
Yes, using data.append() in a for loop.
...but you can, using a custom property for your untransformed binding and a propertyChange script to transform any new value before it's assigned to the actual property.
pyDataSet supports slicing, so if he just wants the first 20 items, he can use pyDs[:20].
Or... what exactly are you filtering for? Specific data? A specific number of rows? If we know that info we can help. Your original post looked like the top 2 rows... so that was the example.
So backup and tell us the constraints for filtering the dataset.
hello @bschroeder I have found solution using idea suggested by @pascal.fragnoud and @Transistor.
Normally what I was searching is filtering somme rows of dataset instead to show all of then.
I recently installed the ingration toolkit. For functions like where() or leftJoin() how can I pass a query result to the expression? I've tried putting db.runQuery scripts in to your {path.to.source.dataset} but can't seem to get that to work. However, I've successfully used them when referencing tags that query the data, but I feel like I should be able to directly use the query in the expression...
Expressions ≠ Scripts.
If you have a query or historian binding supplying data to a component property (likely a custom property), you can reference that property in an expression binding (not a script).
If you have objects in scripts, use the scripting functions my module supplies. If you have objects in UI properties, use the expression functions my module supplies.
