Filtering report data in a perspective view
I use a report viewer in a perspective view and I want the user to be able to select for which date he wants to see the data in the report from the perspective view.
Is there a simple way to perform this ?
Here is an example of a row in my report
Create a start and end date time input and pass those values to the report viewer as parameters and use them in the reports data query.
Hi , how do you pass the value to the parameter in a querry ? Do you use a tag ?
Here's an example from one of my meter data reports. I have a date time input for the start and end date time parameters. There is a button that will set the start and end times to the parameters but you could just directly bind them also.
This is the data query for the report
I do not understand how do you link the end & start date input from the perspective to the querry, can you elaborate please ?
Thank you
In my 2nd screenshot you can see my two parameters "start" and "end", i created them by clicking the plus icon up by the parameters area in the top left. They are referenced in the query by the question marks.
In the perspective view you can bind the date time inputs to the report viewer's "start" and "end" parameters or assign their values on a button event like i did. Hopefully that answers your question, if not let me know what specific part you are having trouble with.
You can go through these two videos as well.
