In Ignition 8.1.1
Does anyone have suggestions as to how to go about finding things in Tags, in the Tag Browser when it shows red text like and value is 'Error_Configuration'?
Unless there’s a better way, I’m trying to use the script console, using system.tag.browse()
More specifically, in the script console, if I pass system.tag.browse() the direct path to the problematic tag I can see its value is ...u'value': [null, Error_Configuration...
What I’m wanting to do is start at the top of the Tag directory structure and recursively work through all the subdirectories looking for abnormalities/misconfigurations and such?
So you are trying to find a way to search for the ‘Error_Configuration’ message?
Like this?
Exactly yes 'Error_Configuration' or 'Bad_Stale' and any variations that could be the origin/source of the (structure contains invalid parent data types) warning.
I’m mainly trying to find a way to search Tags for the noted values. Search instead of mousing through countless tags, folders, subfolders etc.
This will return everything with a “Bad” quality under the default provider, though it seems to also return folders and UDT definitions. Ive honestly never used this before so i may be mistaken.
results = system.tag.browse("[default]", {"recursive":True, "quality":"Bad"})
for i in results.getResults():
print str(i['fullPath'])
