Hi
I would like to make a find replace in the tag browser, but I get this error message
Does any one know this permissions is. I can't find the solution for it.
Should be on your gateway under config, you can change the settings for your tag provicder and assign permissions on creating/editing and reading/writing tags. I would check your permissions to see if you are authorised to edit these.
I can read, write, change and delete tags as long as I'm doing it the tag browser one by one, but the when using find and replace I can't get it to work.
Is it a remote tag provider?
nop
