Find/Replace is not working for me with Ignition v7.7.4. It had been working fine on this machine with 7.7.1. It seemed with 7.7.4 at first some simple searches were occasionally working, but now no searches are working whether all Windows are selected or not.
Cancel button does not work and after I Close the Find/Replace and come back to it, the top button sometimes still says Cancel rather than Find.
This is displayed in the Output Console in [color=#FF0040]red [/color]after attempting a Find:
Exception in thread "AWT-EventQueue-2" java.lang.NoClassDefFoundError: java/util/function/BiConsumer
at com.inductiveautomation.factorypmi.designer.search.ComponentCursor.<init>(ComponentCursor.java:74)
at com.inductiveautomation.factorypmi.designer.search.WindowCursor.next(WindowCursor.java:69)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.advance(SearchObjectAggregator.java:116)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.next(SearchObjectAggregator.java:98)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.hasNext(SearchObjectAggregator.java:74)
at com.inductiveautomation.ignition.designer.findreplace.SearchReplaceDialog$SearchTask.initialize(SearchReplaceDialog.java:918)
at com.inductiveautomation.ignition.designer.findreplace.SearchReplaceDialog.executeSearch(SearchReplaceDialog.java:390)
at com.inductiveautomation.ignition.designer.findreplace.SearchReplaceDialog$3.actionPerformed(SearchReplaceDialog.java:187)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: java.util.function.BiConsumer
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 44 more
