Find Tag numbers for HACH WIMS integration
I am trying to add a few more tags to Hach WIMS, they use a tag ID # to grab the tag from the SQL database. How do I cross reference that ID to an actual tag name?
Reversing the id used in the sqlt_data tables involves reversing the lookup process completely, going from sqlth_te to sqlth_scinfo and sqlth_drv:
You'd need to look at the sqlth_te table and reference the id column. That table has a tagPath column that gives you the full path to the tag.
Thank you, found it!
