Finding cause of error in logs
How would I find which tag is causing the following ‘Error in Derived tag’
com.inductiveautomation.ignition.common.expressions.ExpressionException: No value found at [0, 5] in dataset
at com.inductiveautomation.ignition.common.expressions.SubscriptExpression.handleDataset(SubscriptExpression.java:168)
at com.inductiveautomation.ignition.common.expressions.SubscriptExpression.execute(SubscriptExpression.java:120)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$IsNullFunction.execute(DefaultFunctionFactory.java:557)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$IfFunction.execute(DefaultFunctionFactory.java:2060)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.reference.DerivedTagValueActorFactory$DerivedTagValueActor$Executor.execute(DerivedTagValueActorFactory.java:263)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.reference.DerivedTagValueActorFactory$DerivedTagValueActor.processIncomingValue(DerivedTagValueActorFactory.java:108)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.reference.TagReferenceValueActorFactory$TagReferenceValueActor.tagChanged(TagReferenceValueActorFactory.java:178)
at com.inductiveautomation.ignition.gateway.tags.subscriptions.ProviderSubscriptionManagerImpl$TagChangePublish.run(ProviderSubscriptionManagerImpl.java:1365)
java.lang.ArrayIndexOutOfBoundsException: null
First, put your error between three triple ticks to make it legible
my code
Unfortunately it wont tell you exactly which tag is generating the error in the logs. However, you can narrow it down a bit.
  1. You know it is a derived tag
  2. You know it is doing some work on a dataset
If you’ve been doing any work on tags recently particularly tags which meet those two criteria, I would start there. Also, look for derived tags which have a bad quality.
In the future I would recommend wrapping expressions which can be error prone, such as lookup() in a try() expression.
