I am getting tag path from dataset column, then storing it to a variable.
data = event.source.data
tagPath = data.getValueAt(ClickedItem, “tagPath”)
For Eg. Value in tagPath variable will be like Pumps/Motor 1
Now I need to check that datatype tagPath variable (which has tag path).
Then I need to check that tagPath variable (which has tag path) is UDT or not?
tried few option like system.tag.read, system.tag.browseConfiguration & system.tag.browseTags but I was unsuccessful.
Hopefully Thank you.
It looks like system.tag.browseConfiguration() has what your looking for.
The example at the bottom of the link shows how to check the tag type.
I tried this, It gives data type for all the sub tags comes under the provided path.
browsePath = system.tag.browseConfiguration(tagPath , False)
the above code gives tagPath for all its sub tags.
I want the data type of the provided path not its sub tags.
as i explained earlier my tagPath variable will be having value like "Pumps/Motor 1" (which will UDT mostly, some times it may not UDT also. This path is what I need to validate.)
I need to check that tagPath variable (which has tag path) is UDT Instance or not?
Thanks,
If you want the DataType
system.tag.read("path/to/tag.DataType").value
If you want TagType
from com.inductiveautomation.ignition.common.sqltags.model.types import TagType
v = system.tag.read("path/to/tag.TagType").value
print TagType.getTypeForValue(v)
Thanks a lot, Its Working.
along with it I was also trying the following code.
config = system.tag.read(assetTagPath + ".TagType").value
print config
It gave me a output @console
10
I searched for online help document, But, I couldn't able to figure out what does this 10 refers to?
Thanks a lot, Kyle.
for your Immediate response.
I got what I was expecting.
Hi @Kyle_Chase , How can I find data type for multiple tags, can you share the syntax for it please
If i understood you correctly, seems like you just need a list and a for loop.
tagList = ["New Folder/New Tag.dataType",
"New Folder/New Tag 1.dataType",
"New Folder/New Tag 2.dataType"]
for tag in tagList:
v = system.tag.read(tag).value
print v
If you're using Ignition 8.0+, you should use system.tag.readBlocking() or system.tag.readAsync() instead of system.tag.read().
tagValues = [tag.value for tag in system.tag.readBlocking(tagList)]
for dataType in tagValues:
print dataType
Thanks a lot for your time and efforts @leonardo.godoi for solving my query, Is there any possibility to read the dataType for all the tags. I am currently working on resetting all the tag values to zero irrespective of its data type. I am facing some difficulties can you help me with some logic please
@Vijay, this is a duplicate of your own thread, Reset tag values to zero. Please don't post twice about the same problem but you could have added a link in this post to your new question. (I have now done it so no further action is required.)
