Can anyone explain me how to find out keyCode on keypress event of TextBox component?
I am trying to find out enter button keyCode when enter key get pressed in the TextBox component.
Hello,
You should use the predefined constants defined here: http://docs.oracle.com/javase/7/docs/api/java/awt/event/KeyEvent.html
For example, catching the enter key:from java.awt.event import KeyEvent
if event.keyCode == KeyEvent.VK_ENTER:
print "yep"Best,
Based on your code, I want to print “yep” when I press the “Enter” Key on a Text Field.
I wrote this code on the PropertyChange Event Script of this Text Field component.
I used the following code, per your recommendation but it gives me an error:
import KeyEvent
print "yep"
if event.keyCode == KeyEvent.VK_ENTER: print "yep"
You missed a bit
You are probably already aware but just in case… print is for the script editor etc not a client
Put this in a key pressed event in your component:
if event.keyCode == event.VK_ENTER:
system.gui.messageBox("Test")
Thank you very much!!
