I am trying to start a new designer project with a node in the project panel that will open a workspace. I follow the instruction in the programming pdf but this first section doesn’t compile for me and the javadoc is talking about a manager factory.
long newId = designerContext.getLockManager().newResourceId();
As shown above I cannot access the newRessourceId from my startup function
[code]public class DesignerHook extends AbstractDesignerModuleHook {
@Override
public void startup(DesignerContext context, LicenseState activationState) throws Exception {
long newID = context.getLockManager()
}[/code]
Can you suggest a solution or a new documentation on getting started with coding the designer.
thanks
