Hello All,
I have a brand-spankin’ new install of Ignition on a new install of Ubuntu Linux, and I’m trying to connect to mySQL.
I’m a newbie at ALL of this (except maybe Linux). I can’t get the connection to work. Here are the specifics:
Linux: Ubuntu 12.04.2 LTS (64-bit version) on a DELL PowerEdge SC1420, 4Gb RAM, ~150Gb disc
MySQL: 5.5.31-0ubuntu0.12.04.2 plus MySQLWorkbench
Ignition: 7.5.8 (build 1410 | 64-bit)
I confirmed mySQL was running OK, started Ignition, then setup a DB connection inside Ignition, and it immediately faulted.
Here is the error message I received:
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Communications link failure The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.)
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:194)
com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:150)
com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.run(DatasourceManagerImpl.java:1103)
java.lang.Thread.run(Thread.java:724)
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
sun.reflect.GeneratedConstructorAccessor52.newInstance(Unknown Source)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
java.lang.reflect.Constructor.newInstance(Constructor.java:526)com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1117)
com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:355)com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2461)
com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2498)com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2283)com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:822)
com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47)sun.reflect.GeneratedConstructorAccessor47.newInstance(Unknown Source)
com.mysql.jdbc.Util.handleNewInstance(Util.java:411)com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:404)
com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:317)org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
java.net.ConnectException: Connection refused
java.net.PlainSocketImpl.socketConnect(Native Method)
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
java.net.Socket.connect(Socket.java:579)sun.reflect.GeneratedMethodAccessor24.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.lang.reflect.Method.invoke(Method.java:606)com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:332)com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:305)
com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:822)com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47)
Any suggestions would be appreciated. In the meantime, I planned to focus on ensuring mySQL is correctly set up and listening on the right port, etc…
