Is the way a flex view is handled changed in 8.0.3?
because it looks like this now:
while grow is set.
in 8.0.2 i did get the expected behaviour.
Are you using a Flex Repeater, or a Flex Container?
We did make some adjustments to how Flex Repeaters display instanced Views, but our changes were meant to repair something that had regressed from a previous change, so Flex Repeaters should be behaving correctly now.
Could you copy the Flex whatever you’re using and paste the copied JSON into this thread?
It is with a flex repeater.
The flex repeater repeats with the width of the view now, even when the view is configured to grow.
On another view in this project I just changed the width of the view to fit in the window, but isn’t a flex view just the thing we want to be flexible in width and height when we set it to grow/shrink?
In 8.0.2 everything works as normal, but in 8.0.3 i got an extra empty space on my view(with the flex repeater on it).
Here the json for the page where the flex repeater is on:
"custom": {},
"events": null,
"params": {
"Overview": false
"permissions": null,
"propConfig": {
"params.Overview": {
"paramDirection": "input",
"persistent": true
"props": {
"defaultSize": {
"height": 500,
"width": 300
"root": {
"children": [
"events": {
"dom": {
"onClick": {
"config": {
"script": "\tself.session.custom.SubMenu \u003d False"
"scope": "G",
"type": "script"
"meta": {
"name": "Button"
"position": {
"grow": 0,
"shrink": 1
"propConfig": {
"meta.visible": {
"binding": {
"config": {
"expression": "!{view.params.Overview}"
"type": "expr"
"position.basis": {
"binding": {
"config": {
"expression": "if(toboolean({view.params.Overview}),\u00270px\u0027,\u002750px\u0027)"
"type": "expr"
"props": {
"style": {
"borderStyle": "double",
"borderWidth": "2px",
"classes": "OverviewButton"
"text": "Terug"
"type": "ia.input.button"
"meta": {
"name": "Label"
"position": {
"basis": "2px",
"grow": 0,
"shrink": 1
"type": "ia.display.label"
"meta": {
"name": "FlexRepeater"
"position": {
"basis": "320px",
"grow": 1,
"shrink": 0
"propConfig": {
"props.instances": {
"binding": {
"config": {
"queryPath": "Pages",
"returnFormat": "json"
"type": "query"
"props": {
"direction": "column",
"path": "Shared Pages/Main Menu/Templates/SubMenuButton"
"type": "ia.display.flex-repeater"
"meta": {
"name": "root"
"props": {
"type": "ia.container.flex"
and here the json for the view of the flex itself:
"custom": {},
"events": null,
"params": {
"Page": "test1",
"PageID": "value",
"StatusTagPath": ""
"propConfig": {
"custom.key": {
"persistent": true
"params.Page": {
"persistent": true
"params.PageID": {
"persistent": true
"params.StatusTagPath": {
"persistent": true
"props": {
"defaultSize": {
"height": 50,
"width": 200
"root": {
"children": [
"events": {
"dom": {
"onClick": [
"config": {
"params": {
"Page": "{view.params.Page}",
"PageID": "{view.params.PageID}"
"view": "Overview/ComponentsOverview"
"scope": "C",
"type": "nav"
"config": {
"script": "\t# Write your script here\n\tPage \u003d self.view.params.Page\n\tPageID \u003d self.view.params.PageID\n\tself.session.custom.PageName \u003d Page\n\n\tsystem.perspective.navigate(view \u003d \u0027Overview/ComponentsOverview\u0027, params \u003d {\u0027Page\u0027:Page,\u0027PageID\u0027:PageID})"
"enabled": false,
"scope": "G",
"type": "script"
"config": {
"id": "menu",
"type": "close"
"scope": "C",
"type": "dock"
"config": {
"script": "\tself.session.custom.PageName \u003d self.view.params.Page\n"
"scope": "G",
"type": "script"
"meta": {
"name": "Button"
"position": {
"basis": "43px",
"grow": 8,
"shrink": 1
"propConfig": {
"custom.ExecuteScript": {
"binding": {
"config": {
"expression": "now(3000)"
"type": "expr"
"onChange": {
"enabled": null,
"script": "\tdef TagpathStatus(Tagstring):\n\t\ttags \u003d Tagstring.split(\"+\")\t\t\n\t\tstatus \u003d 4\n\t\tfor tag in tags:\n\t\t\ttagvalue \u003d system.tag.readBlocking([tag])[0].value\n\t\t\t\n\t\t\tif tagvalue \u003d\u003d 0 or tagvalue \u003d\u003d 3:\n\t\t\t\treturn 0\n\t\t\telif tagvalue \u003d\u003d 1 or tagvalue \u003d\u003d 4:\n\t\t\t\tstatus \u003d 1\t\t\n\t\t\telif status \u003d\u003d 2 or tagvalue \u003d\u003d 5:\n\t\t\t\tstatus \u003d 2\t\n\t\treturn status \n\t\n\tColor \u003d \u0027#000000\u0027\n\tif self.view.params.StatusTagPath !\u003d \"\":\t\n\t\tif self.view.params.Page \u003d\u003d \"Thiopaq\":\n\t\t\tif system.tag.readBlocking([\"[Ecco]Paques EcoS/ECO Aan\"])[0].value \u003d\u003d 1:\n\t\t\t\tColor \u003d \u0027#FF0000\u0027\n\t\t\telse:\n\t\t\t\tColor \u003d \u0027#00FF00\u0027\n\t\telse:\n\t\t\tif self.view.params.Page \u003d\u003d \"Decanter\":\n\t\t\t\tif system.tag.readBlocking([\"[Ecco]Pieralisie/Decanter Alrm\"])[0].value \u003d\u003d 1:\n\t\t\t\t\tColor \u003d \u0027#FF0000\u0027\n\t\t\t\telse:\n\t\t\t\t\tColor \u003d \u0027#FFFF00\u0027\n\t\t\telse:\n\t\t\t\tif TagpathStatus(self.view.params.StatusTagPath) \u003d\u003d 0:\n\t\t\t\t\tColor \u003d \u0027#FF0000\u0027\n\t\t\t\telif TagpathStatus(self.view.params.StatusTagPath) \u003d\u003d 1:\n\t\t\t\t\tColor \u003d \u0027#FFFF00\u0027\n\t\t\t\telif TagpathStatus(self.view.params.StatusTagPath) \u003d\u003d 2:\n\t\t\t\t\tColor \u003d \u0027#00FF00\u0027\n\t\t\t\telse:\n\t\t\t\t\tColor \u003d \u0027#FF00FF\u0027\n\n\tself.props.style.borderColor \u003d Color"
"props.text": {
"binding": {
"config": {
"path": "view.params.Page"
"type": "property"
"props": {
"style": {
"borderColor": "#000000",
"scripts": {
"customMethods": [
"name": "TagpathStatus",
"params": [
"Tagstring"
"script": "\t\n\ttags \u003d Tagstring.split(\"+\")\n\t\n\tstatus \u003d 4\n\tfor tag in tags:\n\t\ttagvalue \u003d system.tag.readBlocking([tag])[0].value\n\t\t\n\t\tif tagvalue \u003d\u003d 0 or tagvalue \u003d\u003d 3:\n\t\t\treturn 0\n\t\telif tagvalue \u003d\u003d 1 or tagvalue \u003d\u003d 4:\n\t\t\tstatus \u003d 1\t\t\n\t\telif status \u003d\u003d 2 or tagvalue \u003d\u003d 5:\n\t\t\tstatus \u003d 2\n\t\t\t\n\t\t\t\n\t\t\t\n\treturn status "
"messageHandlers": []
"meta": {
"name": "Label"
"position": {
"basis": "2px",
"grow": 0,
"shrink": 0
"meta": {
"name": "root"
"props": {
After looking at your Flex Repeater, I think it was working for you previously because you were falling back on unintended behavior caused by a bug which we have since fixed. In your Flex Repeater, set FlexRepeater.props.useDefaultWidth to false.
