Flex repeater in perspective
Hi Friends,
I’m trying to show values for the instances with flex repeater and the path is given to another view. on that view I want to get values from the database and when binding the flex repeater instances to names query, I can see those values in the Instances properties and on the view, it showing for like username ten times instead of different values which are coming from the database. I have a property bound that is used in the query to filter out the result.
Please can you any suggestions?
Thanks,
Priyanka
Hi @Priyanka.Khandge, could you post the code (with the correct formatting using ```), or any screenshots of what you are seeing.
From the description, it seems like something is not quite bound correctly, but it’s hard to tell without the code :slight_smile:
Hi, @matthew.ayre Thank you for giving me a response. Solve using a parameter.
