PERSPECTIVE
I have a flex repeater that shows instances of a view. This view has both view parameters and custom properties.
When the number of instances changes on the flex repeater, the view parameters for each instance track accordingly (as expected) but the custom properties for each view stay at the same position in the flex repeater.
See:
Here we see the number is a parameter and the letters are a custom property. #1 is linked with A and #3 is linked with C.
After a new instance is added (#2), #1 is still linked with A but now #2 is linked with C as opposed to C sticking with instance #3.
As for trying to do away with custom properties and replacing with view parameters, the instances and each instances' parameters have a tag binding to a script that produces the instances as a list and I need to be able to modify some of the items in the view, thus I have to use custom properties.
I know this is probably expected behavior from the flex repeater, I'm wondering if there is something I can do to get around it.
Version: 8.1.20 (b2022082313)
