Flex Repeater with Pie Charts
I´m trying to generate dinamically Pie Charts with a Flex repeater based on number of months I want to see.
one example of wanted result not generated dinamically:
To do so, I´ve got my Flex repeater with the path to a Pie chart
I binded my named Query with a transform on the instances of the Flexbox
    if quality.isGood() and value is not None:
        py_data = system.dataset.toPyDataSet(value)
        unique_months = sorted(set(row['LOC'] for row in py_data))
        all_data = []
        for month in unique_months:
            count_zero = 0
            count_one = 0
            for row in py_data:
                if row['LOC'] == month:
                    state = row['STATES']
                    if state == 0:
                        count_zero += 1
                    elif state == 1:
                        count_one += 1
            data = [
                {"label": "Zero Value States", "value": count_zero},
                {"label": "One Value States", "value": count_one}
            all_data.append({"data": data})
        return all_data
    else:
        return []
wich works fine
Now I´m not sure how to bind the Pie View to this instances to see the result
the path to the view should be to your pie view,
this view would need a param named data which will contain the {value,label} for your one pie
It works! thanks @victordcq
Pie flex repeater
