Flint - VS Code help
Hi, any chance there is someone that could help me figure out why am I getting errors when trying to use Flint VS Code extension to create folders and modules in scripting?
I still get error like this:
Ignition Gateway Provider not available
When I try to create folder, it does nothing and throws this error, when I create a module, it throws the same error but creates the module.
I have the Project Scan Endpoint module installed. My local gateway is running in docker and i can reach it on localhost:9088, and can verify that the module is working. This is the config i use in VS Code:
    "ignitionFlint.ignitionGateways": [
            "label": "The_Project",
            "address": "http://localhost:9088",
            "projectPaths": ["/workspaces/bwdesign-docker/data-folder/projects/The_Project"],
            "updateDesignerOnSave": true,
            "forceUpdateDesigner": true,
            "supportsProjectScanEndpoint": true
I tried providing projectPath as absolute, relative and this weird /workspaces path.
Does this GET request show {"supported":true}? This just makes sure your issue is with the VS Code extension and not the gateway module.
localhost:9088/data/project-scan-endpoint/confirm-support
Yes sir.
Just to be sure, when you say config file, you mean the .code-workspace for your project right? The correct way is to use a .code-workspace at the root of your project and then the projectPath’s are the relative paths.
Well that was it, me not using the workspace. Thanks!
