For looping in Jython?
machine = 'd'
number = {01,02,03,04}
for x in machine:
	for y in number:
		print (x,y)
returns
('d', 1)
('d', 2)
('d', 3)
('d', 4)
How would a guy return?
('d01')
('d02')
('d03')
('d04')
How to concatenate ‘str’ and ‘int’ objects?
machine = 'd'
number = [01,02,03,04]
for x in machine:
	for y in number:
		print (str(x)+str(y))
The following forces two digits for y as in your example output:
machine = 'd'
for x in machine:
	for y in number:
		print x + '%02d' % y
If you want the parentheses and quotation marks in the output, change the last line to:
		print "('" + x + "%02d')" % y
time = system.tag.read("[default]SCADA/Time/Clean Time Entry")
params = {"TBC":0,
		"TGC":0,
		"TPC":0,
		"RCT":0,
		"GHS":0,
		"TS":time.value,
		"TBLNum":group}
#list of machine tables in db
machine = 'd'
number = {99,98,97,96}
for x in (machine):
	for y in number:
		group = (str(x) + str(y))
		for i in group:
			print params
returns
{'RCT': 0, 'TPC': 0, 'TGC': 0, 'GHS': 0, 'TBC': 0, 'TBLNum': 'd99', 'TS': Thu Sep 19 14:00:00 CDT 2019}
Why does this print 12 times?
Why is it always passing d99?
How would one return the following?
{'RCT': 0, 'TPC': 0, 'TGC': 0, 'GHS': 0, 'TBC': 0, 'TBLNum': 'd98', 'TS': Thu Sep 19 14:00:00 CDT 2019}
{'RCT': 0, 'TPC': 0, 'TGC': 0, 'GHS': 0, 'TBC': 0, 'TBLNum': 'd97', 'TS': Thu Sep 19 14:00:00 CDT 2019}
{'RCT': 0, 'TPC': 0, 'TGC': 0, 'GHS': 0, 'TBC': 0, 'TBLNum': 'd96', 'TS': Thu Sep 19 14:00:00 CDT 2019}
machine = 'd'
for x in (machine):
	for y in number:
		params = {"TBC":0,"TGC":0,"TPC":0,"RCT":0,"GHS":0,"TS":time.value,"TBLNum":group}
		for group in params:
			print params
LOL getting closer
machine = 'd'
for x in (machine):
	for y in (number):
			print params
			break
You were close, try this.
time = system.tag.read("[default]SCADA/Time/Clean Time Entry").value
machine = 'd'
number = [99,98,97,96]
for x in (machine):
	for y in (number):
		params = {"TBC":0,"TGC":0,"TPC":0,"RCT":0,"GHS":0,"TS":time,"TBLNum":group}
		print params
Or similar, cleaning up the variable names a bit:
machines = ["d"]
machine_numbers = [99, 98, 97, 96]
params = []
for machine in machines:
    for number in machine_numbers:
        params.append(
                "TBC": 0,
                "TGC": 0,
                "TPC": 0,
                "RCT": 0,
                "GHS": 0,
                "TS": time.value,
                "TBLNum": "%s%s" % (machine, number),
    print group
One important thing to note: number = {99,98,97,96} creates number as a set, which is an unordered sequence. If the final output order matters, you should use a list ([]) or tuple (()) instead of the set initializer ({}).
The order doesn't matter in this case. Thanks for this example! It helps connect some dots for me....This is like string formatting in C. Python is hella wild.
This script for loops through a named query params arg if there are any future readers. Your mileage may vary.
machines = ["d"]
machine_numbers = [01,02,03,04,05,06,07,08,09,10,11,12,13,14,16,17,19,21,22,23]
nq = 'New Folder/clean'
params = []
        params.append(
                "TBC": 0,
                "TGC": 0,
                "TPC": 0,
                "RCT": 0,
                "GHS": 0,
                "TS": time.value,
    print group
    system.db.runNamedQuery(nq, group)
    system.db.clearNamedQueryCache(nq)
{'RCT': 0, 'TPC': 0, 'TGC': 0, 'GHS': 0, 'TBC': 0, 'TBLNum': 'd99', 'TS': Thu Sep 19 15:00:00 CDT 2019}
1
{'RCT': 0, 'TPC': 0, 'TGC': 0, 'GHS': 0, 'TBC': 0, 'TBLNum': 'd98', 'TS': Thu Sep 19 15:00:00 CDT 2019}
1
