Is it possible to force a SQL query to update a tag value that has a SQL Query expression binding?
Back story…
I have several Client tags that are bound to SQL Query expressions. I have the Polling Mode set to “Off” because these tag values could go for weeks or months and never need updating because the values in the database typically won’t change. They are values that are customizable by the user that represent colors to be used for various device states.
However, I have a window that allows a system admin to change these values using and Editable Table component. I want to have a button that the admin can press when he is done with the changes to immediately force the SQL Query for those Client tags so that the UI is properly updated to display the new colors.
Can forcing the query be done? Or do I need to set the query to some polling rate even though there may never be updates?
Thanks -
