I have a legacy SCADA system “Wonderware” that writes the values firstname/lastname in a DB for a station and I want to use that data to authenticate the same user in ignition.
Can I use a query to “force” ignition to read the value from the db and login the same person? I am trying to make it easier for the person to leave the Legacy SCADA and not have to re-login to my ignition app.
Thanks!
I don’t understand how that authenticates anyone, but, taking the question at face value:
Vision does not allow you to login without some valid user. However, you can run scripts to switch what user you are using (system.security.switchUser).
I would do something like the following:
- Have a bare project with auto-login enabled. This project’s only purpose will be to display some intermediate ‘loading’ graphic for a split second before the rest of this process kicks off.
- On startup of that project, use scripting to query the DB (?) for the authentication info, then pass it to
switchUser.
- Call
system.util.retarget to swap from the ‘empty’ project with the autologin user to the real project (now that you’re authenticated).
You need the second project so that auto-login isn’t a confusing/misleading operation on your real project, and to make it easier to lock down the main project.
Sorry I didn’t specify this, I’m developing this project in perspective. The switchuser function doesn’t work in perspective. If I have the string “B.Johnson” I want to force perspective to authenticate “B.Johnson” from my Active directory source in my project.
