When using a parameterized drop down list, what is the best way to force it to show the first option by default?
If I save the view, it will load with that option, but if I change the options, it defaults to “Select…” when what I would like it to do is just default to its first option.
I’m pretty sure someone will suggest some scripting to address this, which is helpful. But what I want to know is if there is a default parameter on the component to do this.
It starts like this
But when changing the area, it doesn’t default to the first option
@lrose thanks for this. Here is what ended up working. What happens is that the new options will bind properly but the actual value does not update. So the tag change script has to be on the options because if they are on the value, and it doesn’t change, the script never fires…
