Forcing a 0 if the parameter does not come up in results
I have a query where I'm looking for the Top 5 results of downtime over a 4-week period in our database, and getting the information from each of those 5 categories for each of those 4 weeks. The problem is that some of those weeks may not have any results for one of those 5 categories. How do I make the query return a result where it includes the parameter that had no result and then the quantity for the correlating column be 0?
And before you ask, the reason I need it this way is because it's going in a stacked bar chart, and without the 0 value, it will create gaps between the stacked bars.
SELECT dispatchl2ldb.dispatchType,
	dispatchl2ldb.reasonDesc,
	IF(dispatchl2ldb.reasonDesc = :topCat1,1,
	IF(dispatchl2ldb.reasonDesc = :topCat2,2,
	IF(dispatchl2ldb.reasonDesc = :topCat3,3,
	IF(dispatchl2ldb.reasonDesc = :topCat4,4,
	IF(dispatchl2ldb.reasonDesc = :topCat5,5,0))))) AS catOrder,
	SUM(dispatchl2ldb.minsDown) AS minTotal,
	WEEKOFYEAR(dispatchl2ldb.reported) AS Week
FROM dispatchl2ldb
WHERE dispatchl2ldb.reasonDesc = :topCat1
  AND dispatchl2ldb.line = :line
  AND dispatchl2ldb.shiftID = :shiftID
  AND dispatchl2ldb.dispatchType = "Waiting On"
  AND WEEKOFYEAR(dispatchl2ldb.reported) = :week
  OR dispatchl2ldb.reasonDesc = :topCat2
  OR dispatchl2ldb.reasonDesc = :topCat3
  OR dispatchl2ldb.reasonDesc = :topCat4
  OR dispatchl2ldb.reasonDesc = :topCat5
  OR dispatchl2ldb.reasonDesc = :topCat1
  AND dispatchl2ldb.dispatchType = "Operational Fix"
  AND dispatchl2ldb.dispatchType = "FDT"
GROUP BY reasonDesc, Week
ORDER BY catOrder ASC
While I don't know the solution to your problem, I can tell that you have a lot of redundancy in that query. It can be simplified to:
SELECT
  d.dispatchType,
  d.reasonDesc,
  CASE d.reasonDesc
    WHEN :topCat1 THEN 1
    WHEN :topCat2 THEN 2
    WHEN :topCat3 THEN 3
    WHEN :topCat4 THEN 4
    WHEN :topCat5 THEN 5
    ELSE 0
  END AS catOrder,
  SUM(d.minsDown) AS minTotal,
  WEEKOFYEAR(d.reported) AS Week
FROM
  dispatchl2ldb d
WHERE
  d.reasonDesc IN (:topCat1, :topCat2, :topCat3, :topCat4, :topCat5)
  AND d.line = :line
  AND d.shiftID = :shiftID
  AND d.dispatchType IN ('Waiting On', 'Operational Fix', 'FDT')
  AND WEEKOFYEAR(d.reported) = :week
GROUP BY
  d.reasonDesc, Week, d.dispatchType
ORDER BY
  catOrder ASC;
i don't know the exact solution here, but you may want to look into
and SQL Server COALESCE() Function
How does data get into the DB? It may be easier to force insert a "0" row at the end of each day. Or make a second, simple, query that you run before this one and if it returns nothing then insert a "0" row.
We ended up finding a way to make it work, and rewrote it to put the week totals in one table.
SELECT d.reasonDesc,
	SUM(CASE WEEKOFYEAR(d.reported) WHEN :week THEN d.minsDown ELSE 0 END) AS wC,
    SUM(CASE WEEKOFYEAR(d.reported) WHEN ((:week)-1) THEN d.minsDown ELSE 0 END) AS w1,
    SUM(CASE WEEKOFYEAR(d.reported) WHEN ((:week)-2) THEN d.minsDown ELSE 0 END) AS w2,
    SUM(CASE WEEKOFYEAR(d.reported) WHEN ((:week)-3) THEN d.minsDown ELSE 0 END) AS w3,
    CASE d.reasonDesc
    	ELSE 0
  	END AS catOrder
FROM
	dispatchl2ldb d
WHERE
	AND d.line = :line
	AND d.deleted = 0
GROUP BY
	d.reasonDesc
ORDER BY
	catOrder ASC
