Forcing scroll bars off in views?
I have some circular based SVGs that I have embedded into perspective views, and set the extents of the view to the diameter of the SVG. For example:
Screen Shot 2022-04-21 at 3.41.59 PM
But when I rotate the SVG by a non-multiple of 90 degrees, Ignition says that the extents of the SVG are now outside the view, and adds scroll bars:
Screen Shot 2022-04-21 at 3.42.39 PM
Is there anyway to force the scroll bars off?
And yes, before you ask, I am doing skeuomorphic design, and I am aware of the tradeoffs that I am making. And in this particular use case they are perfectly reasonable choices. However in general I do not recommend a skeuomorphic approach.
Add an overflow style property to the container that has the svg and set it to visible.
In this case the the SVG was in the root container of the view, so the style addition was:
And now when the SVG is rotated, it looks like this in the view:
Screen Shot 2022-04-22 at 6.53.36 AM
Note that because I was consuming this view as an embedded view, I had to add the style property to both the root container where the SVG was, and also to the embedded view container that linked back to the original view
