I have a Formatted Text Field with its committedValue linked bidirectionally to a client tag. When I change the Field the new value is written to the tag.
However, when I carry out a hot update or close and re-open the window the Field does not show the value in the tag, even though the committedValue is set correctly. There seems to be a disconnect between the Field’s text and committedValue properties. At the moment I am having to manually set the Field’s text property in the window’s internalFrameActivated event.
