Formatting Label text in an expression
Hi all,
Once again I am trying something new and need some direction. I have a label that I setup this expression for…
concat("The Selected Binder is ", {Root Container.Label 2.selectedBinderName})
It works fine, but I would like to be able to make the two different strings a different font.
Where should I look for this?
Thanks, Steven
The labels work with HTML formatting. Have you tried adding that into your string to set your font for the different sections?
You can use a selection of HTML markup tags for formatting text.
The font tag is limited though, you can only set bold,color and size I believe.
https://docs.inductiveautomation.com/display/DOC79/HTML+in+Ignition
@bpreston & @MMaynard
I am binding properties to the label in a Property Expression.
The Expression is this...
concat("The current Binder is ",{Root Container.Power Table.selectedBinderName} ,"The current Topic is ",{Root Container.Label 2.selectedTopicName})
When I try to put html here...
It looks great in design mode. But when I go to preview or the client, it does not see the html formatting.
When I try to put it in the Expression, it does not like it.
What am I missing?
Thanks, Steven
concat("<html>","The current Binder is ",{Root Container.Power Table.selectedBinderName} ,"<font color='red'><b>","The current Topic is ",{Root Container.Label 2.selectedTopicName},"</b></font></html>")
Ah, I see the html formats the entire string not each string separately.
concat("<html>The current Binder is <b>", {Root Container.Power Table.selectedBinderName}, "<br></b>The current Topic is <b>", {Root Container.Label 2.selectedTopicName})
So this gives me bold and line break right where I want it.
Thanks for the help!!
Steven
