The following error occurs for the RSS feed on the forums:
An invalid character was found in text content.
Line: 66 Character: 715
<description>by Carl.Gould (Posted Wed Dec 31, 1969 4:33 pm)<br/>Ah, well, you're binding to a dataset. When binding to a dataset, you don't need a fallback value, since an empty dataset is a perfectly legal value. If you want some other dataset instead of an empty dataset on an empty selection, make a dynamic property (lets call it "EmptyDataset", fill it with the values you'd like to see, and bind whatever dataset this is trying to fill in to an expression like:<br /><br /><div class="codewrapper"><div class="codetitle"><b>Code:</b></div><div class="codecontent">if(<br />
