I have a button that has some code underneath it. Also in the root container where this button is located I have a dynamic property.
The name of the dynamic property in the root container is : prod_date
The code i have is as follows:
if event.source.parent.prod_date == 0:
fpmi.db.runUpdateQuery(.........)
else:
fpmi.gui.messageBox(.....)
When I run this code I get the following message:
[quote]Traceback (innermost last):
File “event:actionPerformed”, line 32, in ?
AttributeError: instance of ‘com.inductiveautomation.factorypmi.application.components.BasicContainer’ has no attribute ‘prod_date’
at org.python.core.Py.AttributeError(Py.java)
at org.python.core.PyObject.__getattr__(PyObject.java)
at org.python.pycode._pyx24.f$0(<event:actionPerformed>:32)
at org.python.pycode._pyx24.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.factorypmi.application.script.ScriptManager.runCode(ScriptManager.java:245)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:145)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:287)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at $Proxy0.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
[/quote]
Can you explain to me why it is saying there is no attribute?
Thanks and have a great day.
