I know fpmi is not officially supported under vista, but…is there a java guru here whoa can explain why i cannot connect to the designer ?
below is the error code :
java.net.MalformedURLException: For input string: "0:0:0:0:100:7f:fffe:8080"
at java.net.URL.<init>(Unknown Source)
at com.inductiveautomation.factorypmi.common.gateway.GatewayInterface.getConnection(GatewayInterface.java:74)
at com.inductiveautomation.factorypmi.common.gateway.GatewayInterface.getResponse(GatewayInterface.java:134)
at com.inductiveautomation.factorypmi.common.gateway.GatewayInterface.getResponse(GatewayInterface.java:109)
at com.inductiveautomation.factorypmi.common.gateway.GatewayInterface.getResponse(GatewayInterface.java:101)
at com.inductiveautomation.factorypmi.common.gateway.DTGatewayInterface._registerAsDesigner(DTGatewayInterface.java:176)
at com.inductiveautomation.factorypmi.common.gateway.DTGatewayInterface.access$600(DTGatewayInterface.java:26)
at com.inductiveautomation.factorypmi.common.gateway.DTGatewayInterface$DesignerLoginTask.run(DTGatewayInterface.java:612)
at com.inductiveautomation.factorypmi.designer.util.PriviledgedDesignerTask$UserTask.run(PriviledgedDesignerTask.java:218)
at java.lang.Thread.run(Unknown Source)
It seems tha the problem come from the ip adress format “0:0:0:0:100:7f:fffe:8080”
Thanks,
I’ve the solution.
