FPMI designer won't load
I am attempting to look at an old FPMI project. I created an VM and installed FPMI, FSQL, & MYSQL from the original project Unified Installer that I have archived.
The installation went well. I made sure that I had Java Version 6 installed.
I had a problem with the starting of FPMI, and with the help of Tech support (thanks Paul) we figured out it was an IE compatability thing. I am now using Chrome and I can get to and see the Gateway now.
I can start the application and navigate through the screens OK, so I don’ believe it is a java thing.
HOWEVER, the problem I hahe is I cannot start the designer. I get an error. I am posting the error below.
[attachment=0]FPMIerror.jpg[/attachment]
java.lang.NoClassDefFoundError: com/calmetrics/factoryhmi/application/gateway/DataSet
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClassCond(Unknown Source)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at java.security.SecureClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.access$000(Unknown Source)
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at com.sun.jnlp.JNLPClassLoader.findClass(Unknown Source)
	at java.lang.ClassLoader.loadClass(Unknown Source)
	at com.inductiveautomation.factorypmi.plugins.reporting.ReportingDesignerHook.<init>(ReportingDesignerHook.java:39)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.lang.Class.newInstance0(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at com.inductiveautomation.factorypmi.designer.model.DesignerPluginManager.loadPlugins(DesignerPluginManager.java:62)
	at com.inductiveautomation.factorypmi.designer.FPMIDesigner$2.run(FPMIDesigner.java:430)
	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
	at java.awt.EventQueue.access$400(Unknown Source)
	at java.awt.EventQueue$2.run(Unknown Source)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.calmetrics.factoryhmi.application.gateway.DataSet
	... 35 more
Any ideas?
