Hey all,
I’m trying to upgrade my FPMI project as per the ignition upgrade guide. When I try to use my FPMI gateway backup, it seems like it works, but the ignition page continues to say ‘Processing’ with the spinning progress thing. The output is included below.
Starting [createTempDir] ... C:\WINDOWS\TEMP\legacyfpmi3446529947651237183conv (0 ms)
Starting [extractBackup] ... done. (468 ms)
Starting [verifyBackup] ... Found backup from version 3.3.2 (b2754) (0 ms)
Starting [openDatabase] ... done. (1 seconds)
Starting [upgradeDatabase] ... DB found at v.38 (500 ms)
Starting [importSystemSettings] ... done. (0 ms)
Starting [importImages] ... done. (31 ms)
Starting [importAuthProfiles] ... done. (0 ms)
Starting [importDatasources] ... done. (0 ms)
Starting [importProjects] ... Imported projects: [IADemo, PMCS] (0 ms)
Starting [cleanup] ... done. (1 seconds)
Finished.
It looks like ignition is happy with the upgrade, but it constantly says ‘Processing’ afterwards. If I look around ignition after the upgrade, there is no sign it completed (no projects, connections, etc).
Thanks in advance
