Hi all,
We make graphics libraries for SCADA/BMS screens, and our first free pack for Perspective has just been approved on the Exchange:
What's inside:
- Three 3D-rendered symbols: a cutaway gas condensing boiler (with an animated flame), a centrifugal pump and an actuated on/off valve
- 256 px PNG images with transparent background, one per state (stopped / running / alarm; closed / open / alarm for the valve), all sharing the same framing so the image can be swapped from a tag without the symbol moving
- Two views:
Symbol(embeddable, withsymbolandstateparams) andDemo, a small heating loop with STOPPED / RUNNING / ALARM buttons driven by a singleview.custom.modeproperty - MIT licence, so you can use and modify it in commercial projects
The same files, plus screenshots, are also on GitHub: GitHub - Sinoptek/ignition-3d-symbols: Free 3D-rendered equipment symbols for Ignition Perspective: boiler, pump and valve, with states, animated PNG and a demo view. MIT licence. By SINOPTEK. · GitHub
What we tested: Ignition 8.3.10 in a Perspective session. What we haven't tested yet: importing through the Designer, Vision, and 8.1. If anyone tries it there or runs into any problem with the import, I'd really appreciate hearing about it and will fix it.
Two questions for the community:
- Would you use an animated PNG inside the Image component in production, or do you prefer cycling frames with a binding?
- Which equipment would be most useful next: chillers, AHU sections, tanks, heat exchangers?
Thanks, and any feedback is welcome!
