Free database for Maker, what do you use
I need to decide on the type of database I am going to use.
I am familiar with Microsoft SQL and use that at work. Is MySQL free? Is there something better out there that anyone recomends I look into?
Thanks in advance for your guidance and recomendations!
MariaDB works well
There are the 3 big ones:
  • MS SQL is paid, has a lot of extensions to the languages
  • MySQL is free, and also has a lot of (different) extensions to the language
  • PostgreSQL is free, but tries to adhere to the SQL standard.
MariaDB is a fork of MySQL by the original authors of MySQL after Sun was bought by Oracle. So it’s pretty similar but the project have diverged a bit over the years.
For whatever use a Maker can have, any database will do.
Unless you use the express edition, which is free but has some limitations: single core, 10GB Max per database.
For small projects, you might get away with a simple single-file sqlite database
The majority of volunteer MySQL developers went over to MariaDB. If I couldn't use PostgreSQL, I'd be using MariaDB.
I believe there is a 2GB ram allocation limit as well.
If it’s just for personal use, you can also just use SQLite. There’s a seeded driver + translator now available, so you can pretty easily point it to a local database. I think there’s a few issues (resolved in 8.0.15) with history, but if you just need simple relationship mapping it works great. Extremely portable, too - it’s a single file on disk you can plainly copy.
Also have to agree with Griffith here, I just needed some simple data storage, installed sqlite on my RPi 4, made a DB, and got it connected in less than 15 minutes. If helpful, I could make up a quick walkthrough.
:+1:
One of my "little tricks" also has been to place that SQLite DB within the data/projects/ folder so that it gets incorporated into the gateway backup. Wouldn't want to probably use this strategy for tag history or something that grows large over time, but it is a nice technique for bundling simple database assets that should be atomic with your Gateway.
FYI, In addition to MS SQL Express edition, MS now offered the the full version of SQL Server for free as a developer edition. The caveat is that the license is only for development and test systems, and not production.
But given that Maker edition is also only licensed for non-commercial use, then this shouldn’t be not an issue.
I use the developer version for developing (duh) work projects and haven’t had an issue with it.
This seems like a nice trick for projects like the sample dashboard, where each user define their dashboard
