I am attempting to set my module as a free module with the tag in the pom.xml. However it fails on build when this is there, and succeeds with the tag removed.
I have tried, to no avail, lower case and camelCase per the suggestion in this thread: https://inductiveautomation.com/forum/viewtopic.php?f=89&t=14848&p=54557&hilit=freemodule&sid=b4a2a602374469130cf96638014278be#p54557. I have also set my ignition-maven-plugin version to 1.0.9, which did not work.
What am I missing that would cause this?
The error I get is this:
Here is an excerpt of my pom.xml
<artifactId>myArtifactID</artifactId>
<version>1.0.0</version>
<packaging>pom</packaging>
<name>myArtifact</name>
<description>myArtifactDescrition</description>
<freeModule>true</freeModule>
<properties>
<ignition-sdk-version>7.8.0</ignition-sdk-version>
</properties>
Thank you.
