Free space from Ignition folder
Hello!
In a server Inductive Automation folder there is Ignition folder wich is 23GB, probably is from the older Vision project that is still runing. I wonder if there are any files , logs or temp I can delete to free some space.
the current folder structure is as follow:
We have another Ignition4 folder we use for perspective project.
Any ideas on whether this is normal or not welcome.
Cheers!
All those data_$timestamp, logs_$timestamp, etc folders are backups we create on uninstall. If you don't need them, you can remove them.
Thank you @paul-griffith , that clarify me a lot where those come from.
