From CSV to MySQL
Hey guys,
Im really stuck trying to pull data from a csv files and insert it into a database, I’ve seen a example and i tested succesfully for 1 record on the file, but what im trying to do is get 3 different values
the code im using is:
adir = ‘C:\import\’
rFile = open(adir + ‘file.txt’, ‘r’).readlines()
for line in rFile:
print line
system.db.runUpdateQuery("INSERT INTO csv (job) values (%s)" %(line))
the file that Im trying to read is the following
job=J1234
product=4321
quantity=500
Sorry Im a newbie on python
You can do the following:[code]adir = ‘C:\import\’
job = rFile[0].replace(“job=”, “”)
product = rFile[1].replace(“product=”, “”)
quantity = rFile[2].replace(“quantity=”, “”)
print job, product, quantity[/code]Use those variables in your SQL query.
Thanks Travis, this worked great
Hey, going on the same kind of operation but now writing,
what im trying to do now is to write a query from my DB to an txt file.
Im totally lost on this.
i have tried the following but no luck so far.
resultset = system.db.runQuery("SELECT sum(produced), wo, circuit  FROM prodkomax1 WHERE wo = '33'")
   if len(rs) > 0:
      data = rs[0][0]
      filename = system.file.saveFile("c:\\control\file.txt")
      if filename != None:
         system.file.writeFile(filename, data)
also… is there any way to delete files from here? I mean, after make a read from a file delete it.
Thanks for your support.
I think you just want:rs = system.db.runQuery("SELECT sum(produced), wo, circuit FROM prodkomax1 WHERE wo = '33'") if len(rs) > 0: data = rs[0][0] system.file.writeFile("c:\\control\file.txt", data, 1)The 1 on writeFile appends it. Also to delete files you can do this:import os os.delete("C:\\path\\to\\file")
