The following SQL runs fine in the Database Query Browser but will not work as a SQL query binding because of ‘{’ brackets on the join clause. What is the syntax one uses to get around this?
SELECT op_code_log.code, b_codes.the_type, form_header.form_number
FROM {oj op_code_log LEFT OUTER JOIN b_codes ON op_code_log.code = b_codes.code LEFT OUTER JOIN form_header ON op_code_log.form_serial_id = form_header.form_serial_id}
