having some trouble getting the python ftp code to work. trying to retrieve a file and getting an error on this line:
s=ftp.retrbinary(‘RETR Test.txt’, open(‘C:\Documents and Settings\cannin\Desktop\Test.txt’,‘wb’).write)
In my app I need to:
#1 edit a text file - write a part number into the text file that is on another drive #2 trasfer a program file from the HMI computer to the other drive #3 save the file from the other drive back to the HMI computer #4 delete the file from the other drive
Can anyone help me with python ftp code examples for these 4 scenarios?
this is what i have so far - Is there a way to retrieve a file defined indirectly, as you can see in the code below I was trying to compile “test.txt” and retrieve it but get file not found as its trying to find a file called “d”
thank you.
import os
import system
from ftplib import FTP
ftp = FTP(‘127.0.0.1’)
ftp.login(’’)
a = “te”
b = “st”
c = “.txt”
d = a+b+c
s=ftp.retrbinary(‘RETR “d”’, open(‘C:\Documents and Settings\cannin\Desktop\test2.txt’,‘wb’).write)
print s
ftp.close()
perfect, thank you. one other question, I havnt been able to find anything on editing a text file. Is it possible to delete or write text into a text file through ignition? for example I need to delete a 5 digit number from a text file and then write a different 5 digit number into the file. thank you.
You can bring in the text file as a string using system.file.readFileAsString, use python’s string.replace function to replace the number with a new number, and then write back to the file using system.file.writeFile:
