Good day,
I am trying to build something like this in ignition perspective:
I am using an XYChart
xAxis defined as Date
yAxis defined as Category
The data I am using is like this
the idea is to position in the chart with ‘x’ and then plot a column with ‘dur’ width.
But somehow I am not able to do that, can anyone give me some light with an idea?
Thanks in advance
I would start by playing with the example in the manual.
Then come up with a strategy based on your data. It could as simple using an end_date instead of dur (duration). Assuming dur is in minutes, you could convert to milliseconds then calculate the end_date based on x with system.date.addMillis(x, durMillis).
Date add functions link:
Take a look at this Exchange item. Ignition Exchange | Inductive Automation
It takes a bit to figure out how to model up your data, but once you do it's not to bad. But the chart comes out like you want.
