How can I target maximum pause time for Garbage collector in Ignition 8.1.
I would like to set it to 100ms. I know that the java default is 1 second.
Put something like this in your ignition.conf file:
wrapper.java.additional.Z=-XX:MaxGCPauseMillis=100
Replace the .Z with a suitable unique integer.
Note that it isn't truly a maximum, as that cannot be guaranteed, but a target maximum.
Do you know what is the java default for maximum pause time for Garbage collector in Ignition 8.1?
The default is 200ms.
