Gateway Access Controlled with Active Directory Users
I am trying to control access to my gateway page using roles that are generated by an active directory user source. Every time I change who has permissions to view a page it will not allow access. If I try to login on the gateway it does not recognize any users from the active directory group. The odd thing is that these logins work just fine when accessing projects through the application. I have tried making a test internal account and I can get everything to work with that account using Authenticated/Roles/Administrator. What am I missing?
Check your identity provider, user source, etc on that same page to make sure you're pointing to the same ones you're using in your project. If necessary, show your config here so we can help more.
