I have tried to trigger a script from the Client and Gateway Scripts but they do not run and there are no errors reported when triggered. What am I missing? My trigger tag is listed on the tag page.
Downtime_Reporting/TRG
Here is my script which should work.
trg = system.tag.read(“Downtime_Reporting/TRG”).value
if trg == 1:
system.tag.write(“Downtime_Reporting/DT_Location”,event.source.parent.getComponent(‘Drop Machine ID’).selectedLabel)
system.tag.write(“Downtime_Reporting/DT_Reporter”,event.source.parent.getComponent(‘Drop Reporter’).selectedLabel)
system.tag.write(“Downtime_Reporting/DT_Cause”,event.source.parent.getComponent(‘Drop Reason’).selectedLabel)
system.tag.write(“Downtime_Reporting/DT_Description”,event.source.parent.getComponent(‘DT Description’).text)
system.tag.write(“Downtime_Reporting/DT_Time”,event.source.parent.getComponent(‘DT Time’).intValue)
system.tag.write(“Downtime_Reporting/Save_Data_Trg”,1)
