Hello,
Once again this error has occurred… It happens occasionally and then sometimes when reload is performed it opens Gateway unknowingly. This time I have been working on a project and now I am not even able to take a backup of my project or gateway. This issue is unknown and not sure what causing this…
This has caused multiple times before, and all I had to un-install and install to make it work again… Please let me know what is an actual problem that causes this.
OS: Windows 10 Home, 64 bit
RAM: 8 GB
Memory: 1 TB
Ignition Version: 8.0.12
See attached screenshots and following wrap log,
###################### Wrapper #################
INFO | jvm 3 | 2020/05/10 00:00:21 | I [p.DesignSession ] [18:30:21]: Change ID: 4 protocol=view-structure-change, session-project=TEST
INFO | jvm 3 | 2020/05/10 00:36:26 | I [p.DesignSession ] [19:06:25]: WebSocket disconnected from session. session-project=TEST
INFO | jvm 3 | 2020/05/10 00:36:28 | I [p.ClientSession ] [19:06:28]: WebSocket disconnected from session. session-project=TEST
STATUS | wrapper | 2020/05/10 00:37:09 | Machine is shutting down.
INFO | jvm 3 | 2020/05/10 00:37:18 | I [o.e.j.s.AbstractConnector ] [19:07:18]: Stopped ServerConnector@25b9c9b{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 3 | 2020/05/10 00:37:32 | I [o.e.j.s.AbstractConnector ] [19:07:18]: Stopped ServerConnector@4a7b83f7{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 3 | 2020/05/10 00:37:32 | I [o.e.j.s.session ] [19:07:18]: node0 Stopped scavenging
INFO | wrapper | 2020/05/10 00:37:32 | Wrapper Process has not received any CPU time for 13 seconds. Extending timeouts.
INFO | jvm 3 | 2020/05/10 00:37:32 | I [IgnitionGateway ] [19:07:20]: Ignition[state=RUNNING] ContextState = STOPPING
INFO | jvm 3 | 2020/05/10 00:37:32 | I [IgnitionGateway ] [19:07:20]: Ignition Gateway shutting down…
INFO | jvm 3 | 2020/05/10 00:37:33 | I [g.ModuleManager ] [19:07:33]: ModuleManager shutting down…
INFO | jvm 3 | 2020/05/10 00:37:33 | I [g.ModuleManager ] [19:07:33]: Shutting down module ‘com.inductiveautomation.reporting’ v5.0.12 (b2020042115)… module-name=Reporting
INFO | jvm 3 | 2020/05/10 00:37:34 | W [c.i.r.g.ReportingGwPerspectiveInit] [19:07:34]: Perspective module was not found or was not running, could not unregister reporting components. module-name=Reporting
INFO | jvm 3 | 2020/05/10 00:37:34 | I [g.ModuleManager ] [19:07:34]: Shutdown of module “com.inductiveautomation.reporting” completed in 240 ms module-name=Reporting
INFO | jvm 3 | 2020/05/10 00:37:36 | I [g.ModuleManager ] [19:07:36]: Shutting down module ‘com.inductiveautomation.opcua.drivers.ablegacy’ v5.0.12 (b2020042115)… module-name=Allen-Bradley Driver
INFO | jvm 3 | 2020/05/10 00:37:36 | I [g.ModuleManager ] [19:07:36]: Shutdown of module “com.inductiveautomation.opcua.drivers.ablegacy” completed in 1 ms module-name=Allen-Bradley Driver
INFO | jvm 3 | 2020/05/10 00:37:39 | I [g.ModuleManager ] [19:07:39]: Shutting down module ‘com.inductiveautomation.opcua.drivers.modbus’ v6.0.12 (b2020042115)… module-name=Modbus Driver
INFO | jvm 3 | 2020/05/10 00:37:39 | I [g.ModuleManager ] [19:07:39]: Shutdown of module “com.inductiveautomation.opcua.drivers.modbus” completed in 0 ms module-name=Modbus Driver
INFO | jvm 3 | 2020/05/10 00:37:40 | I [g.ModuleManager ] [19:07:40]: Shutting down module ‘com.inductiveautomation.opcua.drivers.siemens’ v5.0.12 (b2020042115)… module-name=Siemens Drivers
INFO | jvm 3 | 2020/05/10 00:37:40 | I [g.ModuleManager ] [19:07:40]: Shutdown of module “com.inductiveautomation.opcua.drivers.siemens” completed in 55 ms module-name=Siemens Drivers
INFO | jvm 3 | 2020/05/10 00:37:41 | I [g.ModuleManager ] [19:07:41]: Shutting down module ‘com.inductiveautomation.opcua.drivers.logix’ v4.0.12 (b2020042115)… module-name=Logix Driver
INFO | jvm 3 | 2020/05/10 00:37:41 | I [g.ModuleManager ] [19:07:41]: Shutdown of module “com.inductiveautomation.opcua.drivers.logix” completed in 398 ms module-name=Logix Driver
INFO | jvm 3 | 2020/05/10 00:37:42 | I [g.ModuleManager ] [19:07:42]: Shutting down module ‘com.inductiveautomation.opcua.drivers.dnp3’ v3.0.12 (b2020042115)… module-name=DNP3 Driver
INFO | jvm 3 | 2020/05/10 00:37:42 | I [g.ModuleManager ] [19:07:42]: Shutdown of module “com.inductiveautomation.opcua.drivers.dnp3” completed in 52 ms module-name=DNP3 Driver
INFO | jvm 3 | 2020/05/10 00:37:42 | I [g.ModuleManager ] [19:07:42]: Shutting down module ‘com.inductiveautomation.opcua.drivers.omron’ v3.0.12 (b2020042115)… module-name=Omron Driver
INFO | jvm 3 | 2020/05/10 00:37:42 | I [g.ModuleManager ] [19:07:42]: Shutdown of module “com.inductiveautomation.opcua.drivers.omron” completed in 75 ms module-name=Omron Driver
INFO | jvm 3 | 2020/05/10 00:37:43 | I [g.ModuleManager ] [19:07:43]: Shutting down module ‘com.inductiveautomation.opcua.drivers.tcpudp’ v5.0.12 (b2020042115)… module-name=UDP and TCP Drivers
INFO | jvm 3 | 2020/05/10 00:37:43 | I [g.ModuleManager ] [19:07:43]: Shutdown of module “com.inductiveautomation.opcua.drivers.tcpudp” completed in 0 ms module-name=UDP and TCP Drivers
INFO | jvm 3 | 2020/05/10 00:37:43 | I [g.ModuleManager ] [19:07:43]: Shutting down module ‘com.inductiveautomation.sms-notification’ v5.0.12 (b2020042115)… module-name=SMS Notification
INFO | jvm 3 | 2020/05/10 00:37:43 | I [g.ModuleManager ] [19:07:43]: Shutdown of module “com.inductiveautomation.sms-notification” completed in 40 ms module-name=SMS Notification
INFO | jvm 3 | 2020/05/10 00:37:43 | I [g.ModuleManager ] [19:07:43]: Shutting down module ‘com.inductiveautomation.perspective’ v1.0.12 (b2020042115)… module-name=Perspective
INFO | jvm 3 | 2020/05/10 00:37:43 | E [P.GatewayHook ] [19:07:43]: Uncaught throwable in the Perspective Gateway Event Bus module-name=Perspective
INFO | jvm 3 | 2020/05/10 00:37:43 | java.lang.IllegalStateException: Not valid for write: id=node09uc1kadfh51kye31bf3e7k5f10 not resident
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.session.Session.checkValidForWrite(Session.java:674)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.session.Session.setAttribute(Session.java:806)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.session.Session.removeAttribute(Session.java:832)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.perspective.gateway.session.PerspectiveSessionCollection$ModuleShutdownListener.onModuleShutdown(PerspectiveSessionCollection.java:314)
INFO | jvm 3 | 2020/05/10 00:37:43 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 3 | 2020/05/10 00:37:43 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 3 | 2020/05/10 00:37:43 | at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 3 | 2020/05/10 00:37:43 | at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:399)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.eventbus.Subscriber.dispatchEvent(Subscriber.java:71)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.eventbus.Dispatcher$PerThreadQueuedDispatcher.dispatch(Dispatcher.java:116)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.google.common.eventbus.EventBus.post(EventBus.java:217)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.perspective.gateway.GatewayHook.shutdown(GatewayHook.java:203)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.shutdown(ModuleManagerImpl.java:2561)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.shutdown(ModuleManagerImpl.java:1161)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.shutdownInternal(IgnitionGateway.java:1556)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.shutdown(IgnitionGateway.java:2289)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.ignition.gateway.web.IgnitionWebAppImpl.onDestroy(IgnitionWebAppImpl.java:98)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.apache.wicket.Application.internalDestroy(Application.java:665)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.apache.wicket.protocol.http.WebApplication.internalDestroy(WebApplication.java:613)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.apache.wicket.protocol.http.WicketFilter.destroy(WicketFilter.java:528)
INFO | jvm 3 | 2020/05/10 00:37:43 | at com.inductiveautomation.ignition.gateway.bootstrap.GatewayFilter.destroy(GatewayFilter.java:67)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.servlet.FilterHolder.destroyInstance(FilterHolder.java:164)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.servlet.FilterHolder.doStop(FilterHolder.java:148)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.servlet.ServletHandler.doStop(ServletHandler.java:238)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.handler.AbstractHandler.doStop(AbstractHandler.java:111)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.security.SecurityHandler.doStop(SecurityHandler.java:425)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.security.ConstraintSecurityHandler.doStop(ConstraintSecurityHandler.java:425)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.session.SessionHandler.doStop(SessionHandler.java:519)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.handler.ContextHandler.stopContext(ContextHandler.java:916)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.servlet.ServletContextHandler.stopContext(ServletContextHandler.java:367)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.webapp.WebAppContext.stopWebapp(WebAppContext.java:1450)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.webapp.WebAppContext.stopContext(WebAppContext.java:1415)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.handler.ContextHandler.doStop(ContextHandler.java:980)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.servlet.ServletContextHandler.doStop(ServletContextHandler.java:284)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.webapp.WebAppContext.doStop(WebAppContext.java:547)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.server.Server.doStop(Server.java:454)
INFO | jvm 3 | 2020/05/10 00:37:43 | at org.eclipse.jetty.util.thread.ShutdownThread.run(ShutdownThread.java:127)
INFO | jvm 3 | 2020/05/10 00:37:44 | I [g.ModuleManager ] [19:07:44]: Shutdown of module “com.inductiveautomation.perspective” completed in 491 ms module-name=Perspective
INFO | jvm 3 | 2020/05/10 00:37:44 | I [g.ModuleManager ] [19:07:44]: Shutting down module ‘com.inductiveautomation.opccom’ v5.0.12 (b2020042115)… module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [c.i.o.ModuleHook ] [19:07:44]: Message loop stopped. module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [c.i.o.ModuleHook ] [19:07:44]: Cleaning up native resource collector. module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [c.i.o.ModuleHook ] [19:07:45]: Shutdown native resource collector. module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [c.i.o.ModuleHook ] [19:07:45]: Native thread killed. module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [c.i.o.ModuleHook ] [19:07:45]: Native resource collector has stopped. module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [c.i.o.ModuleHook ] [19:07:45]: COM-OPC Module shutdown. module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutdown of module “com.inductiveautomation.opccom” completed in 354 ms module-name=OpcCom
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutting down module ‘com.inductiveautomation.vision’ v10.0.12 (b2020042115)… module-name=Vision
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutdown of module “com.inductiveautomation.vision” completed in 2 ms module-name=Vision
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutting down module ‘com.inductiveautomation.taghistorian’ v3.0.12 (b2020042115)… module-name=Tag Historian
INFO | jvm 3 | 2020/05/10 00:37:45 | I [h.ModuleHook ] [19:07:45]: Tag Historian module stopped. module-name=Tag Historian
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutdown of module “com.inductiveautomation.taghistorian” completed in 18 ms module-name=Tag Historian
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutting down module ‘com.inductiveautomation.sqlbridge’ v9.0.12 (b2020042115)… module-name=SQL Bridge
INFO | jvm 3 | 2020/05/10 00:37:45 | I [s.ProjectRunner ] [19:07:45]: Project shutdown. module-name=SQL Bridge, project-name=TEST
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutdown of module “com.inductiveautomation.sqlbridge” completed in 0 ms module-name=SQL Bridge
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutting down module ‘com.inductiveautomation.eam’ v3.0.12 (b2020042115)… module-name=Enterprise Administration
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutdown of module “com.inductiveautomation.eam” completed in 1 ms module-name=Enterprise Administration
INFO | jvm 3 | 2020/05/10 00:37:45 | I [g.ModuleManager ] [19:07:45]: Shutting down module ‘com.inductiveautomation.opcua’ v8.0.12 (b2020042115)… module-name=OPC-UA
STATUS | wrapper | 2020/05/10 10:35:31 | → Wrapper Started as Service
STATUS | wrapper | 2020/05/10 10:35:36 | Java Service Wrapper Standard Edition 64-bit 3.5.35
STATUS | wrapper | 2020/05/10 10:35:36 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2020/05/10 10:35:36 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2020/05/10 10:35:36 | Licensed to Inductive Automation for Inductive Automation
WARN | wrapper | 2020/05/10 10:35:49 | Child process: Java version: timed out
STATUS | wrapper | 2020/05/10 10:35:49 | ← Wrapper Stopped
############## End Of Wrapper #################
