Hello,
Having issues getting the communications between a client PC and gateway PC set up correctly. Have a vision project that’s running on the gateway that I’d like to have the “remote” client PC display using Vision Client Launcher. They’re on the same network and I can ping each computer from the other, but the gateway PC does not show up in the Vision Client Launcher when I go to add a project.
However, if I remove all Firewall settings, and I able to connect. What applications do I need to allow through the firewall in order to make the connection with the firewall on?
