Gateway Connection Lost in ignition 8.1.20
I'd start by inspecting the gateway logs on both the primary and backup gateways to see what errors or warnings, if any, are occurring around the time of client disconnects. I would also inspect the vision client logs via the diagnostics menu, again, looking at around the time the client disconnects to see if there are any warnings/errors.
Hopefully there is something in the logs that can point you to a more concrete cause.
Have you been able to narrow down to a specific screen or two on the project, or does it seem to occur regardless of what screen is active?
