Our connection to the gateway keeps temporarily dropping out.
In the designer, at the lower right corner, notifications that the gateway connection is lost, then restored are popping up about once a minute, sometimes more.
I am not seeing anything in the logs indicating a problem and the memory usage and cpu trend are well within normal.
Currently, the only client connected is running on the gateway itself. The connection issue is causing the client to briefly disconnect as well.
You have a 10-second stall showing. Something is disrupting Ignition. You may need IA support looking over your shoulder, as there's nothing else unusual there.
(Are you trying to run the database in the same hardware?)
I would absolutely switch to Linux, but supposing that changing the OS is not an option (there is other software that runs that is not Linux compatible) how would I begin to debug this problem?
First, I would look back in the logs to see if similar time jumps are present whenever the disconnections happen. If so, two actions to take short of OS replacement:
Fix your facility's time synchronization infrastructure, and
File a support ticket with IA.
If not, then I'd still file a support ticket to let IA look over your shoulder, for obvious problems that don't translate very well to this forum.
