Every time I open my computer after it has gone into hibernate, any running clients or the designer will all give the following error every 30 seconds, and never connect to the gateway again (Gateway is up) unless I close them all down and launch them again:
Message: Connection to Gateway lost, due to exception.
Time: Wed May 15 1:58:53PM
Severity: WARN
Logger: com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager
Stack Trace: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Reply from SOCKS server has bad version
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:312)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:450)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:318)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.ping(GatewayInterface.java:869)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.publicPing(GatewayInterface.java:862)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.testComm(AbstractGatewayConnection.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.fishForAliveServer(AbstractGatewayConnection.java:379)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection$GatewayReconnectTask.run(AbstractGatewayConnection.java:592)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Reply from SOCKS server has bad version
at java.net.SocksSocketImpl.connectV4(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:347)
… 15 more
Stack Trace: com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:312)
I am worried that if I deploy a client and it ever hibernates, that my users will have to keep reloading the project and it’s going to become a nuisance. Is there a way to have it automatically reconnect? Another piece of information is that the client machine does have an active internet connection, so there is no reason that it shouldn’t be able to connect again.
